It is currently Sun Oct 12, 2025 3:19 pm
 Post subject: straight intake??
PostPosted: Tue Feb 21, 2006 7:08 pm
i need the straight intake with two pcv feeds.correct :?:
PostPosted: Tue Feb 21, 2006 7:12 pm
only 1 pcv
the other is for your cold start injector
so, basically correct :)
PostPosted: Tue Feb 21, 2006 7:20 pm
yea i know that.what i said :lol: :oops:
PostPosted: Tue Feb 21, 2006 7:21 pm
Think one is for the PCV, the other is required for the idle up line that supplies the ISC - Idle Speed Controller that is located underneath the throttle body
PostPosted: Tue Feb 21, 2006 9:13 pm
is that the same as the cold start injector on the 165/185 kris? that is the one i meant :)
PostPosted: Tue Feb 21, 2006 9:21 pm
Andy,
the Cold Start Injector is located underneath the throttle body and bolted to the intake manifold. This is fed via a pipe from the fuel rail on the 165, "think" this is the same on the 185.
The ISC is seperate to the CSI. The ISC is fed via a pipe to the air intake so that the idle speed can be controlled via the ECU.
So in answer, no the CSI and the idle speed controller are not the same, but it would make life easier if they were in the same unit! :)
