It is currently Tue Oct 07, 2025 4:24 am
 Post subject: HKS Speed Limit Defencer
PostPosted: Fri Feb 01, 2013 5:56 pm
Ive had a good look and can seem to see plenty of people talking about converter/derestrictors and there are some good threads on the issue, however nobody seems to have done a write up on fitting an HKS speed limit defencer specifically. Anyone that has done this will be aware that the instructions come in japanese only and there seems to be no english translation. The unit has 5 seperate wires coming from it and there seems to be no indications as to where the cables go and which wire is which. I am aware there is a +12v and an earth required but cant fathom out which of the other cables are used and exactly where.
Question is, has anyone got one of these fitted and if so, how did you do it???
Cheers guys :P
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Fri Feb 01, 2013 6:28 pm
I thought Muddy Water did one but I'm blowed if I can find it
PostPosted: Fri Feb 01, 2013 7:19 pm
Car Model: ST165
Gijouhei wrote:
Well after finding out the hard way the other day that my ST205 was limited I decided (after much research) to go for the standard HKS SLD as my clocks are already UK and reading in MPH. Spent a good few hours hunting around for installation instructions and was pointed in various places. All in all was a tiny little bit tedious.
So, for the benefit of others:
ECU will have 3 plugs. What you need are:
Big Brown Wire (Earth)
Black/Yellow Wire (12 Ignition Power)
Orange Wire (Speed Signal to ECU)
Check an ECU pinout diagram if you're not too sure where those are but they're all unique from what I can remember and pretty easy to find imo.
Make sure you have a decent set of crimps or needle nose pliers as the bullet crimps supplied aren't the best for the size of wire you'll be crimping, ended up soldering mine.
Black Wire on SLD -> Brown Wire
Red Wire on SLD -> Black-Yellow Wire
White Wire on SLD -> Orange Wire Loom Side
Yellow Wire on SLD -> Orange Wire ECU Side
There may also be a blue wire on the SLD but this is not used from what I can tell. Instructions are only guaranteed for ST205's and not other GT4s as I can't honestly say everything will be the same, I would imagine they are but without having wired one up in one I can't say for certain. SLD also tucks away nicely under the little L-Bracket thing under the ECU that the carpet velcro's onto. Works a treat as far as I can tell. Hopefully this information will help someone.
ST165 turbo 4WD
PostPosted: Fri Feb 01, 2013 8:27 pm
thats brilliant, thanks. I was looking for ages, how did you manage to find it so quick??? :D
