It is currently Thu Oct 09, 2025 5:12 pm
PostPosted: Tue Jan 31, 2006 9:37 pm
Has anyone fitted the low impedance 800cc injectors and got them to work OK ??
Had mine fitted over teh weekend and car does not start - with a power fc & map.
Appears there is no fuel at all.
PostPosted: Tue Jan 31, 2006 11:05 pm
You sure they are low imp??
From what I understand they should be a direct drop in replacement.
ST205 WRC #0002249
PostPosted: Tue Jan 31, 2006 11:20 pm
Yep, 3 ohms, pretty much the same as the stock injectors
Yes, this is pretty much everyones understanding!
However, the theory is being a little tricky to prove one way or the other at present!
PostPosted: Tue Jan 31, 2006 11:46 pm
[pedant]
The one we measured was actually 2.5 ohms
[/pedant]
PostPosted: Wed Feb 01, 2006 12:04 am
and MrT want to see between 2 & 3 ohms within their test procedure
