It is currently Mon Oct 06, 2025 5:22 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 37  Next
PostPosted: Tue Aug 24, 2010 9:26 am
It came with the ST215 Caldina side feed intake plenum :D
PostPosted: Tue Aug 24, 2010 10:29 am
i understand :)
the next is, i wish to find also a good company like you to build radiators for me here in austria
the one good company i was talking told me that 40mm is the maximum depth he can build, but i'am searching for 50mm :?
i doesn't want to buy the TTE pre-radiator for the little as 1700€ :lol:
i have also a little bit different question left, does anyone know the prices of tourqueline propshafts?
i hope this also becomes a project for next year
PostPosted: Tue Aug 24, 2010 10:26 pm
I've spoken to CTG TorqueLine about getting a prop shaft made up. Adrian at Fensport has done the same. The biggest problem will be the expense as there is nothing available off the shelf. I think they also require on old OEM prop shaft so that they can bond in the UJ's and splined shafts etc.
PostPosted: Wed Aug 25, 2010 8:20 pm
Hi Don,
looks like a expensive invest, the propshaft is not the problem but it looks like a massive grouß buy....we will see...
today i got the oil for the new engine
[img][img]http://img841.imageshack.us/img841/9288/elft.jpg[/img][/IMG]
PostPosted: Fri Aug 27, 2010 12:08 pm
today i got post
TTE Group A Spec Intercooler
[img][img]http://img825.imageshack.us/img825/3892/ttellk1.jpg[/img][/IMG]
5mm higher against oem
[img][img]http://img829.imageshack.us/img829/7900/ttellk4.jpg[/img][/IMG]
i have to do a smart repaire
8 against 7 row oem + some air buffles
OEM intercooler
Uploaded with ImageShack.us
Kris, i can sent you bigger pics for your homepage if you want?
PostPosted: Fri Aug 27, 2010 2:16 pm
nice!
if you redo the lagging pictures of the underside would be good
PostPosted: Fri Aug 27, 2010 6:27 pm
i will do this next time when the intercooler is out of the car :)
now the intercooler is mounted and 2 problems was to follow
- code 54
- damaged 25A fuse from the jabsco pump
i changed the fuse to a 30A and measured 20A absorption, absolut ok as 21A is the maximum
-> the reason for that is a higher back pressure from the radiator core
and then i startet with the intercooler water level sensor, which was ok
hmmm...????...i solved the problem after some testing
the problem is the higher flow ration in the core that let the sensor work down even the intercooler is full of water
the TTE intercooler is definitiv absolut different even it looks like a OEM
PostPosted: Fri Aug 27, 2010 8:36 pm
Yes please with the pictures and additional information! :)
PostPosted: Sat Aug 28, 2010 11:22 am
pics are sent to you 8)
you can get infor here or feel free to ask any question
PostPosted: Sat Aug 28, 2010 7:30 pm
today i noticed a higher boost as the Defi warns me at 1,2bar
i have no BC or gauge mounted (display can't can show me boost)
PostPosted: Sun Aug 29, 2010 3:52 pm
If you are seeing higher boost on the Defi do you think this is because the TTE charge cooler core is giving you less pressure drop?
PostPosted: Sun Aug 29, 2010 4:53 pm
i think the TTE intercooler have a higher pressure drop in front of the way better cooling which is also the reason for the higher boost
i was around 1bar just with the exhaust system which is a raise of 0,2bar in the rage of 4000rpm to 5000rpm
the car runs like in the past with blitz boost controller :lol:
PostPosted: Tue Aug 31, 2010 3:42 pm
forgot to say that the water volume is raised by ~1/4L in the intercooler
PostPosted: Thu Sep 09, 2010 4:17 pm
small update
[img][img]http://img3.imageshack.us/img3/8590/blitzturbo1.jpg[/img][/IMG]
[img][img]http://img84.imageshack.us/img84/3851/blitzturbo2.jpg[/img][/IMG]
[img][img]http://img688.imageshack.us/img688/4403/blitzturbo3.jpg[/img][/IMG]
[img][img]http://img838.imageshack.us/img838/1705/blitzturbo4.jpg[/img][/IMG]
the turbo is damaged but i hope to get'em reconditioned soon
can anyone give me a feedback to this hybrid turbos
and i also got my facelift wheels back from powder coating
[img][img]http://img530.imageshack.us/img530/9443/faceliftwheels.jpg[/img][/IMG]
i will put on Toyo R1R 205/50 16
PostPosted: Mon Oct 25, 2010 4:26 pm
Hi folks,
a small update,
two weeks ago i become the head back from catcams in belgium as i let them do a setup of camshafts, springs and adjustable cam gear for me (just to inform, the whole setup was cheaper against parts on the market)
on wednesday the gen.4 head goes to a engine center where it becomes new valve guides, and as i am to addle i also let them do the valve grinding work :lol:
- Cat springs
- Jun valve guides
- Ferrea Super Alloy valves
and i also see the group a spec turbo oil adapter
[img][img]http://img714.imageshack.us/img714/954/zylinderkopf1.jpg[/img][/IMG]
[img][img]http://img227.imageshack.us/img227/4752/zylinderkopf2.jpg[/img][/IMG]
[img][img]http://img521.imageshack.us/img521/1933/zylinderkopf3.jpg[/img][/IMG]
possible bimetall valves, i can't can estimate it exacly
[img][img]http://img41.imageshack.us/img41/6334/zylinderkopf4.jpg[/img][/IMG]
[img][img]http://img258.imageshack.us/img258/8529/zylinderkopf5.jpg[/img][/IMG]
the valve buttom is different
and also the contour
[img][img]http://img829.imageshack.us/img829/8751/zylinderkopf6.jpg[/img][/IMG]
[img][img]http://img529.imageshack.us/img529/1177/unbenanntkm.png[/img][/IMG]
i forgott, the plan for the whole project is in the background :lol:
