It is currently Fri Oct 10, 2025 10:43 am
 Post subject: a/c compressor clutch
PostPosted: Tue Aug 24, 2010 3:13 pm
Hi, can anyone shed some light as to where the A/C compressor clutch is situated on a St 205 .
thanks
PostPosted: Tue Aug 24, 2010 7:43 pm
Think this is located in the compressor...
PostPosted: Tue Aug 24, 2010 8:30 pm
i'm getting a ticking sound when car is idling, could it be the compressor clutch?
PostPosted: Tue Aug 24, 2010 9:21 pm
Probably not, this is most likely the vent system for the fuel tank... blip the throttle and the "tick tick tick" will disappear :)
PostPosted: Tue Aug 24, 2010 9:57 pm
Thanks Kris
PostPosted: Tue Aug 24, 2010 10:21 pm
The clutch went bad on my old 185 engine - sounded like a noisy bearing.
The clutch is actually built into the pulley. You'll notice the centre of the pulley stays still while the engine turns (unless aircon is on of course).
PostPosted: Tue Aug 24, 2010 10:31 pm
I got a noise like that from my A/C magnetic clutch bearing when I overtightened the drive belt. This eventually knackered the bearing. At least you can buy the clutch assembly separate from the compressor which saves a bit of dosh.
PostPosted: Wed Aug 25, 2010 12:04 am
thanks for the input, nice one
PostPosted: Wed Jul 25, 2012 3:36 pm
yeah, £400 for just the clych assembly! lol
St205 WRC - Running sweet.
