It is currently Mon Apr 29, 2024 11:02 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 56  Next
PostPosted: Wed Jun 03, 2009 8:22 pm
to the car out tonight for a spin and it goes like a rocket, but i has a feeling the turbo seals are going :( is there any way of cheking if thay have gone?
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Wed Jun 03, 2009 8:26 pm
how do you feel that the turbo seal is gone?
the engine burns oil if they they are damaged you can see this by smoke out of the muffler and when you check the engine oil level
PostPosted: Wed Jun 03, 2009 8:43 pm
when i started the car tonight and it was idleing ther was light blue smoke coming out he back of the exhaust :( it dosent smock when you out drining it or on boost you get a bit of over fuling smock but thats it, from what i have read and here if it smoke when the car is idling then its turbo seals
BRD Page
PostPosted: Wed Jun 03, 2009 8:50 pm
true, sounds like the seals
PostPosted: Wed Jun 03, 2009 8:56 pm
ow bugger lol gess this meens ill have to get my get turbo sooner than i pland lol was thinking of getting the Toyota Celica twin entry S148 240 - 380 £699.00
http://www.turbotechnics.com/docs/turbo/s148.htm
BRD Page
PostPosted: Wed Jun 03, 2009 9:31 pm
When the turbo seals go you usually get white/blue smoke from the exhaust after a few minutes idle time. If your symptoms match then it does look like turbo seals.
PostPosted: Wed Jun 03, 2009 9:34 pm
yes this is what im getting :( is it still ok to drive with the turbo like this? will it damage the engine?
PostPosted: Fri Jun 05, 2009 9:12 pm
think I may have sorted the turbo out :O) bin chatting to my mate and he say that I might of bin smoking because of the battery being flat and the ECU and all the electrics not getting the power they need to run properly, and thinking about it the only times it has smoked is when the battery has been flat and the alternator was not working, I stared it yesterday morning with a full battery and there wasn't any smoke and the same when I stared it tonight now that the alternator and battery are ok it didn't smoke, so hoping that is all it is
BRD Page
PostPosted: Fri Jun 05, 2009 11:44 pm
You really need to take the Four for a blast down the dual carriageway, park up then let it idle for 5 to 10 minutes. If the turbo seal have gone then it will start smoking.
Its worth noting that the 3S-GTE engine has a reputation for 'breathing' quite heavily so its quite common for there to be lots of water vapour come out the exhaust on a cool day. It looks like smoke but its actually just vapour. This will mostly disappear when the engine warms up.
PostPosted: Thu Jun 18, 2009 9:57 pm
turbo seems to have stoped smoking :) and is runing very well
just finished making and fitting my cold air feed box, here as sum pics
first I made a cardboard template of the cold air box
then after I had coverer it on fibreglass resin I then raped it in heat reflective shield
then fitted to the car with a cold air piping going in to the box
not shore weather to fit a lid on it as it is a good fit to the liner under the bonnet which is acting like a lid plus I and benefiting from the vent on the top.
BRD Page
PostPosted: Tue Jul 07, 2009 6:28 pm
now with oil cooler
BRD Page
PostPosted: Sat Aug 08, 2009 1:32 pm
just a bit of an update, I went back to Weston performance today to get the map looked at and they found it to be over fuelling lots :( but the good news is that they have now remapped it and it is pushing 353bhp and 300ft/lbs of torque at the fly wheel :twisted: :twisted: and all this power gains is from having an alternator that works :)
BRD Page
PostPosted: Mon Aug 10, 2009 2:35 am
you are still on the stock turbo aye? is it ceramic or steel shaft?
GT Four Adovansu
PostPosted: Mon Aug 10, 2009 6:32 am
yes stock ct20 im not to shore if it is ceramic or steel but i think the turbo cam from a WRC st205 if that any help :)
BRD Page
PostPosted: Mon Aug 10, 2009 7:12 am
if it came off the WRC then its most likely a steel shaft.
The americans are going up to 20psi on the steel shaft ct26 rev 2 :evil:
GT Four Adovansu
Users browsing this forum: No registered users and 181 guests
