It is currently Sun Oct 12, 2025 2:54 pm
 Post subject: CV boot changing
PostPosted: Sat Aug 01, 2009 8:07 pm
how do you change a CV boot on the near side outer on a gt4 st185?
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sun Aug 02, 2009 2:28 am
imo, best bet is to take it to a local workshop and get a universal stretchy one fitted
PostPosted: Sun Aug 02, 2009 9:22 am
i have dun this 3 times now but the stretch CV boost just wont last and I'm fitting a blue print CV boot witch is a lost thicker and stronger so dint think it will stretch with the stretching tool
BRD Page
PostPosted: Sun Aug 02, 2009 10:29 am
Iirc they are like most other CV joints. (I am about to do one of mine so I'll let you know if they are not). First you need to remove the old boot by cutting it off. Then use a soft faced hammer to give the joint a sharp blow, the hammer should run down the length of the shaft to strike the joint where it is located onto the splines. If the hammer head skims the shaft as it hits the back of the joint then that should be OK. It should shock it free from it's snap ring and allow the CV to slide off the splines!
PostPosted: Sun Aug 02, 2009 2:45 pm
Mixer,
There is an article on our website, www.gtfours.co.uk under the section; how to/ repair & maintain / change CV joint boots.
Its a very early one so doesn't have many pictures etc as some of the other/later writeups have, but it should give you the steps you need . . .
Hope this helps.
Loosey
Loosey@gt4dc.co.uk
Storm Blue JDM ST205
Super White JDM ST205
PostPosted: Tue Aug 11, 2009 12:22 am
Just to add my 2p... don't fit a stretchy boot... they are crap and won't last
PostPosted: Tue Aug 11, 2009 6:19 am
i know i have gone throw 3 of them in the last 2 months os im now fitting a blue print cv boot
BRD Page
PostPosted: Fri Aug 14, 2009 11:51 pm
Right then, please ignore my earlier post as I was talking rollocks! :shock:
Can't have been a four shaft I was thinking of as I've just done mine and it's nothing like I remembered :roll:
To do a 205 shaft it is as follows:
There is a wire type clip just inside the outer section of the inboard joint. It is easy to see when the boot is removed and the grease has been washed out. Pop the wire ring out of the joint and it will then be possible to slide it apart. You should match mark the joint as you take it apart to insure it goes together the way it came apart. The balls will probably drop out and roll off across the floor, well mine did anyway! :lol:
You should now be able to see a circlip on the end of the shaft. You need to remove it to allow the inner section to slide off the splined end of the shaft. When you have done this you can fit boots to either end of the shaft as required after washing the joints out and packing with grease. If there is a rubber piece in the middle of the shaft, you will need to remove it if you are going to fit a boot to the outer CV joint and then slide it back on afterward. I used a tie wrap to secure mine afterward. Reassembly is a simply a reversal of the above :D
PostPosted: Sat Aug 15, 2009 8:23 am
im going to be doing mine to day so ill let you know how i get on:)
BRD Page
