It is currently Mon Oct 13, 2025 12:17 pm
 Post subject: Marking on 205 pistons ?
PostPosted: Fri May 15, 2009 9:42 pm
Does anyone know what the letter (a,b,c) and the number (1,2,3) mean ?
According to the handbook number is diameter, but doesn't say what the letter is.
I'm trying to replace a piston with broken ringland and have 7 spare pistons with either same letter or same number but not both.
PostPosted: Sat May 16, 2009 2:25 pm
Don't care about those markings...
measure your bore and measure your pistons's diameter, and then use the one according to the oil clearance required in the 3SGTE handbook.
Wolf_Tm
TM 250 enduro 2 stroke
PostPosted: Sat May 16, 2009 5:50 pm
I'm not trying to build an engine to last another 100K miles, just bodge one back together to last a few months while I'm building up a forged engine.
PostPosted: Sat May 16, 2009 7:10 pm
It is the same.
I ALWAYS check with gauge Piston to Wall tolerance and bearings oil tolerance, even if the engine have to do 1 km.
Time to check these things is less than the time you spent to write on this forum this thread.
Wolf_Tm
PostPosted: Sat May 16, 2009 10:49 pm
Hi Chris,
The numbers are definately size but i think the letters are too
If I remember right the letters are major (rebore?) sizes and the letters are fine (tolerance) sizes. So you might find a combination of 1a, 1b etc in an engine that's not been worked on
I need to consult the bible to be sute though......
PostPosted: Sat May 16, 2009 11:03 pm
I had a PM from someone who noticed the letters seem to be paired with conrods. I'm wondering if it's small end diameter.
