It is currently Sun Apr 28, 2024 10:10 am
PostPosted: Tue Oct 21, 2008 9:53 am
Seems that most of the parts can now be purchased for a full rebuild. Recently added are brand new CHRA or bearing assemblies to teh average punter.
http://www.melett.com/turbo-parts-catal ... -ct20B.pdf
http://www.melett.com/turbo-parts-catal ... a-ct26.pdf
Lots of usefull specifications too such as compressor wheel & turbine wheel dims, shaft dia.
Also interesting to see some similarities between CT26/CT20b and the landcruiser CT20 - http://www.melett.com/turbo-parts-catal ... a-ct20.pdf
Not that I am suggetsing you even consider rebuilding your own turbo!
PostPosted: Tue Oct 21, 2008 4:50 pm
Mmmm....balancing would be tricky on a DIY rebuild :twisted:
PostPosted: Tue Oct 21, 2008 6:08 pm
This is great info cause no one in the states will touch a ct20.
Maybe with this info I can get it rebuilt or upgraded in the future.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Tue Oct 21, 2008 6:24 pm
What about ATS Racing in Texas?
They should be able to rebuild one fine - I bought a turbo from them in the past.
PostPosted: Tue Oct 21, 2008 11:01 pm
They might now. I remember years ago, the majority of the 3sgte shops here acted like there was something so unknown about the turbo that not much could be done for it.
I had been interested in finding out if it was more economical to get an try and get the ct20b upgraded or get a gt28 instead.
PostPosted: Sun Nov 15, 2009 10:21 pm
This company offers repair parts and 360 degree thrust bearings.
http://www.turbotechnics.com/docs/components/360.htm
http://www.turbotechnics.com/docs/compo ... icekit.htm
I am wondering if one has an extra broken ct20 laying around if they might make a fairly inexpensive upgrade for their car.
It is very interesting comparing the internals of the two turbos.
It seems that the blade on exhaust side of the turbo is slightly smaller than the 185 ct26 and the intake side is larger for the st205.
PostPosted: Sat Dec 12, 2009 10:51 pm
I have one that was taken apart by a turbo-rebuild company over here in the Netherlands... and then they found out that they couldn't repair it...so they didn't bother to put it back to gether again.
It's like a 3d Jigsaw puzzle now :D
ST205 WRC
PostPosted: Fri Aug 17, 2018 3:21 am
Now that companies are offering the 205 with billet wheel replacements, I wonder if one might just get a new steel wheel meant for the wrc ct20b and convert it. The companies offering rebuilt steel ct20s here seem promising, but sadly they seem to be the only ones providing dynos.
Users browsing this forum: No registered users and 185 guests
