Heads up - common speedo problem. http://gt4dc.co.uk/forum/viewtopic.php?f=2&t=7871 |
Author: | Nibbles [ Tue Nov 24, 2020 9:51 am ] |
Post subject: | Heads up - common speedo problem. |
Just an early warning, it appears that speedometers are starting to suffer similar problems with electrolytic capacitors as the ecu. I've now heard of 2 on gen 5's. It manifests as the speedo starting to under-read, so worth keeping a cross check against sat-nav to avoid speeding fines. I haven't seen one myself yet to confirm, apparently it uses unpolarised electrolytics which are quite rare. Worth considering a ceramic instead depending on value. |
Author: | jeff [ Tue Nov 24, 2020 11:41 pm ] |
Post subject: | Re: Heads up - common speedo problem. |
Wish I still had mine to check. ![]() They already have my cars history and of your involvment with the CS ecu repair. Great work and thanks again for all you did. |
