It is currently Mon Apr 29, 2024 6:59 am
PostPosted: Fri Nov 22, 2019 4:44 pm
Hi all,
I need to adjust the handbrake - travel is too much to pass the MOT.
I know you can adjust it at the rear hubs with that little ratcheting wheel each side but I did that when I fitted new rear discs not long ago, & remember it being a right pain to get it 'balanced' either side so each wheel would grab evenly.
Does anyone know if there is an adjustment on/near the handbrake lever itself that simply shortens the cable?
Cheers,
PostPosted: Fri Nov 22, 2019 8:37 pm
There is an adjuster on the handbrake itself, however if it's adjusted too much the shoes in the drums never go fully back leading to other problems.
There should be a self-balancing bar for the handbrake cables, so they would need to be miles out from the handbrake not to be balanced.
The correct procedure is to back off the handbrake lever adjustment so the shoes go fully back, then adjust in the drums until the brakes are just fully off, then adjust the lever back up to be correct. Bearing in mind the shoes settle after changing, I would advise following this procedure.
Users browsing this forum: No registered users and 130 guests
