Climate Control/Aircon Only Runs For A Few Mins
http://gt4dc.co.uk/forum/viewtopic.php?f=2&t=7847
Author:  dunk1302 [ Mon Jun 24, 2019 7:55 am ]
Post subject:  Climate Control/Aircon Only Runs For A Few Mins
Starting a new thread, to save confusion, continued from here
The climate control on my black JDM ST205 blows lovely & cold for a few minutes, then just blows ambient air......
Author:  dunk1302 [ Mon Jun 24, 2019 8:00 am ]
Post subject:  Re: Climate Control/Aircon Only Runs For A Few Mins
@asdrewq - I haven't checked when turning the whole car off & on again, but certainly turning off the aircon & back on again doesn't help
@Nibbles - Yes, the new pump was fitted by a trusted aircon specialists, with all the proper A/C safety gear..... interesting comment about the fans, though - I'll take a look at that
Cheers
Dunk
Author:  dunk1302 [ Tue Jun 25, 2019 6:27 pm ]
Did a bit more investigation tonight - ran the car, with the A/C on "full cold" and blowing at max. This time it didn't even chill the air for a few minutes, it just blew ambient from the start.
Now, am I correct in thinking that in this situation, the condenser fan would be blowing continuously while the AC was switched on? When I looked it wasn't moving - it was free to spin, but showed no interest in moving, even with a flick of encouragement. I left the engine running at idle for a while to get it up to full temperature, but still no sign of life from either of the fans
Time to start checking fuses & relays I reckon...... might run a supply direct to the fan, just to confirm it does still run :wink:
Cheers
Dunk
Author:  Nibbles [ Tue Jun 25, 2019 8:18 pm ]
I'll check the behaviour on mine on Thursday when I'm next in the office.
The things I know that inhibit aircon:
Turning the fan off (as in heater fan).
Lack of aircon fluid (comes from a pressure sensor).
I would expect some sort of interlock on over-temperature, whether it be temperature, pressure or a fan interlock. Not investigated this though.
Author:  Bazross [ Tue Jun 25, 2019 11:46 pm ]
I seem to remember that if it was below 8c it won't work I wonder if the temp sensor is faulty and telling it its to cold to run
Author:  Bazross [ Tue Jun 25, 2019 11:59 pm ]
Dunk
I'll post a link to my private dropbox and it has chassis manual in pdf format in this manual is the repair and stuff relating to the AC
https://www.dropbox.com/s/g2hzv0k9mapl5 ... 9.pdf?dl=0
Hope this helps
Author:  Bazross [ Wed Jun 26, 2019 12:20 am ]
And this one you will need also buddy
https://www.dropbox.com/s/4n6w7w938j4w9 ... 9.pdf?dl=0
Author:  dunk1302 [ Wed Jun 26, 2019 6:53 am ]
Thanks Bazross!! The second of those two look especially interesting with it's AC fault-finding table :)
Dunk
Author:  Bazross [ Wed Jun 26, 2019 10:00 am ]
Dunk
No worries hope you get it sorted
