It is currently Wed Apr 24, 2024 9:04 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Fig8 Seized?
PostPosted: Fri Jun 21, 2019 4:30 pm
You say it works for 5 mins then doesn't again... does it work again immediately once you have restarted the car? Does it work again if you just leave the car running & turn the AC back on 10+ mins later?
Could be evaporator freezing up, system shutting down (via evap temp sensor or system pressure issues), thawing back out...
PostPosted: Fri Jun 21, 2019 8:46 pm
If you've tried changing the pump, I'm assuming it's not just low on refrigerant, as you'd have had it re-filled. Did you get it done properly, as you need to suck out all the air first.
Have you checked the appropriate fans come on with the aircon ?
PostPosted: Mon Jun 24, 2019 7:56 am
.....continued in a new thread of it's own to save confusion HERE
