It is currently Wed May 08, 2024 9:38 pm
 Post subject: Ignition issue
PostPosted: Wed Feb 06, 2019 6:12 pm
Just a quick question about my st205 with a turbo timer installed, hoping someone can answer for me.
Almost every time I turn the key to switch the car off it's as if she wants to completely turn off even when there is at least 10 seconds on the timer. The revs drop as if the car wants to turn off then go back up to idle until the timer is finished then turns off.
Any ideas as to why this might be happening? Thinking it could be a faulty turbo timer.
 Post subject: Re: Ignition issue
PostPosted: Fri Feb 15, 2019 7:05 pm
Sounds like it to me. I'd get rid of it - they are unnecessary with modern oils.
PostPosted: Wed Feb 20, 2019 10:28 pm
Cool cheers mate
PostPosted: Wed Mar 27, 2019 8:37 pm
Having monitored exhaust gas temperature on one of my 4's it became clear that the best way to cool the turbo is to drive gently for the last few miles, and ideally the last couple of miles in 30MPH limit. At idle both oil & water circulation is slow and doesn't take the heat away from hot spots so quickly.
