It is currently Sun Apr 28, 2024 8:48 am
 Post subject: Rear Diff Mount change
PostPosted: Mon Dec 31, 2018 4:21 pm
Hi
I need to change my rear diff mount as its perished and is clunking quite bad, was just wondering would you go for a genuine part or one of the allegedly up graded ones on ebay.
many thanks
PostPosted: Mon Dec 31, 2018 8:44 pm
Get the upgraded. The oem is a poor design, and I have even destroyed a new one under stock 185 power. The 185 and 205 one are the same. Either get a poly filled one, or a solid one. A cheaper options is also polly filling the one you have, or having a plate welded in to make it solid. I have run a solid one myself for over 10 years.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Mon Dec 31, 2018 11:54 pm
I wouldn't advise solid as a little bit of give is a good idea.
I know Mixer on here (and other forums) refurbishes broken ones by removing the old material and refilling with poly. I would expect he can use harder or softer rubber according to preference. Also worth checking what TCB have on offer.
So far I've used standard ones and not had a problem, however they are expensive.
PostPosted: Sun Jan 06, 2019 8:52 pm
Hi
Thanks for the reply, just wanted to check that i have to drop the rear diff to get the diff mount out.
If so will it slide forward enough?
Many thanks
PostPosted: Mon Jan 07, 2019 8:30 am
From what I remember you don't need to undo the propshaft but the memory is hazy. just undo the 2 front bolts plus the ones in the rear mount and the diff will do forward and down enough to wiggle the mount out.
PostPosted: Tue Jan 08, 2019 7:25 am
Never done one myself, but procedure is available online...
http://www.6gc.net/forums/index.php?s=8 ... opic=79843
Plenty of aftermarket options available (as already stated), or oem as well.
hope this helps,
Darryl
eastgt4
PostPosted: Mon Feb 04, 2019 10:56 pm
Thanks for the replys rear diff mount changed and the clunking has now gone.
I am sure it was the original mount hardest part was freeing of the rusted nuts they were a pig !
Users browsing this forum: No registered users and 187 guests
