It is currently Mon May 06, 2024 10:38 am
 Post subject: Clunking from brakes
PostPosted: Wed Feb 20, 2019 5:57 pm
Was woundering if anybody has had the issue where I seem to get a bit of a clunking noise from the front brakes, it only seems to happen when the car has been driven a little. The garage I use wounder if there is a slight bit of movement in the brake pads under braking, from what they can see they say everything looks fine. The car goes and stops absolutely fine, anybody had the same problem or any ideas
Many thanks in advance
 Post subject: Re: Clunking from brakes
PostPosted: Mon Feb 25, 2019 6:07 pm
does the calipers have the P clips on the pads, mine does not and they clunk terribly.
Users browsing this forum: No registered users and 20 guests
