Rear Diff Mount change http://gt4dc.co.uk/forum/viewtopic.php?f=2&t=7831 |
Author: | L4mbert [ Mon Dec 31, 2018 4:21 pm ] |
Post subject: | Rear Diff Mount change |
Hi I need to change my rear diff mount as its perished and is clunking quite bad, was just wondering would you go for a genuine part or one of the allegedly up graded ones on ebay. many thanks |
Author: | cms-gt4 [ Mon Dec 31, 2018 8:44 pm ] |
Post subject: | Re: Rear Diff Mount change |
Get the upgraded. The oem is a poor design, and I have even destroyed a new one under stock 185 power. The 185 and 205 one are the same. Either get a poly filled one, or a solid one. A cheaper options is also polly filling the one you have, or having a plate welded in to make it solid. I have run a solid one myself for over 10 years. |
Author: | Nibbles [ Mon Dec 31, 2018 11:54 pm ] |
I wouldn't advise solid as a little bit of give is a good idea. I know Mixer on here (and other forums) refurbishes broken ones by removing the old material and refilling with poly. I would expect he can use harder or softer rubber according to preference. Also worth checking what TCB have on offer. So far I've used standard ones and not had a problem, however they are expensive. |
Author: | L4mbert [ Sun Jan 06, 2019 8:52 pm ] |
Hi Thanks for the reply, just wanted to check that i have to drop the rear diff to get the diff mount out. If so will it slide forward enough? Many thanks |
Author: | Nibbles [ Mon Jan 07, 2019 8:30 am ] |
From what I remember you don't need to undo the propshaft but the memory is hazy. just undo the 2 front bolts plus the ones in the rear mount and the diff will do forward and down enough to wiggle the mount out. |
Author: | eastgt4 [ Tue Jan 08, 2019 7:25 am ] |
Never done one myself, but procedure is available online... http://www.6gc.net/forums/index.php?s=8 ... opic=79843 Plenty of aftermarket options available (as already stated), or oem as well. hope this helps, Darryl |
Author: | L4mbert [ Mon Feb 04, 2019 10:56 pm ] |
Thanks for the replys rear diff mount changed and the clunking has now gone. I am sure it was the original mount hardest part was freeing of the rusted nuts they were a pig ! |
