It is currently Fri May 10, 2024 11:01 pm
PostPosted: Sat Jul 08, 2017 3:09 pm
Hi need some help with a over heating/fan issue on a ST205
i belive the problem is the fans as when driving the cars temps are fine
if the car is stationary in traffic the temps rise quite sharply
i know there are set things to check this, so id like someone to go through these step by step
im no mechanic but im competent at fixing things, so bare that in mind with any replys
as i would need basic instructions, including the location on any sensors that need un-plugging/checking
thanks in advance
PostPosted: Sat Jul 15, 2017 2:38 pm
know one at all got any advise or help?
PostPosted: Sat Jul 15, 2017 3:22 pm
Are the fans actually running? If you leave the car idling do they come on after a while?
PostPosted: Sun Jul 16, 2017 9:12 pm
For some reason I missed this in the view active topics list until today.
To test the fan system, unplug the fan switch on the bottom of the radiator and the fans should run all the time with ignition on (The switch is normally closed and opens when hot).
It does sound most like fans not working, but there are other possibilities. If the heater goes cold when idling / overheating check the following:
- It's not unknown for the water pump impeller to become detached from the shaft leading to poor circulation.
- Check the coolant is full in the radiator (not the overflow tank). Headgasket failure is rare on the 205 but cracked blocks aren't unknown. If it keeps blowing coolant out then it could be a sign.
PostPosted: Sun Sep 10, 2017 12:30 pm
sorry for the delay as ive been away working im back now so now able to except help!
basically as asked, the fans are non functional, meaning they do not come on at all
is this a fan issue or could id be sensor related?
are both fans connected? as in, if one fails the other will not work also?
my main concern is diagnosing the problem correctly, so i can replace the parts that need replacing
and not working my way through parts that (might) be faulty
so i appreciate any/all help and advise
PostPosted: Sun Sep 10, 2017 3:42 pm
Nibbles will be able to advise better but I would imagine the first step is to establish if this is a mechanical or an electrical problem.
Get the multimeter out and a spare car battery - see if you can power up the fans via the disconnected plug. One of the fans only normally runs when the AC is on as far as I remember.
PostPosted: Sun Sep 10, 2017 4:25 pm
Thanks, maybe worth a mention with regards to the fans, ive had the AC removed sometime ago
are you saying that only one of the fans actually keeps the Rad cool? or have i missunderstood
as far as sensors go, id have to have exact location, to make sure im checking the right one
i believe its lower bottom right of the rad fans (facing the car)?
or is this in the relay
PostPosted: Wed Sep 13, 2017 1:49 am
The sensor that runs the fans is on the bottom tank of the rad nect tp the exit hose. Unplugging this should make the fans run constant with ignition on as this feeds a normally closed relay.
There is also a pressure switch on the aircon plumbing near the diagnostic connector which activates a fan if disconnrcted, It's possible this was removed with the aircon then the fans disabled to stop them running constantly.
Anyway, try unplugging the sensor to confirm whether ir's a sensor issue.
PostPosted: Wed Sep 13, 2017 9:25 pm
Big thanks for the info, with regards to the Air con
this was removed quite some time ago, the Fan issue is only recent
i will check advised over the weekend and report back on monday
PostPosted: Fri Feb 09, 2018 7:57 pm
have done the fan test, connected both fans to battery and both fans do run
im assuming that its a fuse or possible sensor issue, what to try next?
PostPosted: Sat Feb 10, 2018 4:00 pm
have also disconnected the lower rad sensor as advised
both fans do run constant, so fans are all good
is this just a replacement of the sensor in the rad (as seems)?
or maybe fuse issues? I can get these checked but would need to know what
fan fuses to check and exactly what to check for (I wont be doing this, so need full instructions)
few questions before I get any reply's, will any celica 6 gen rad sensor do or is it ST205 specific
as i don't have the part numbers to cross reference, also is the sensor a screw-in type
or will it need some form of sealing as in Plumbing tape
also a used item good enough if working or should I buy new?
would be great to have some help with this now/over the weekend as ive got the time
and the car is up on stands, although I know the rugby's on later
PostPosted: Sun Feb 11, 2018 12:11 am
If the fans run when the sensor is unplugged, then there is nothing wrong with the electrical part except for the sensor itself.
It is possible the sensor is also ok, and the problem is a lack of water circulation at low speed.meaning the bottom of the radiator stays cooler. If you put the heater on full and see if it goes cold when idling for a period, this would indicate a water pump problem or a low coolant level. You could also try feeling the temperature of the bottom radiator tank when idling, or better still measuring if you have an IR surface temperature meter or a thermocouple.
If you change the sensor, from memory coolant will escape while it is out so do it with the engine cold and make sure pressure is released first. With care, you should be able to quickly swap them without losing a huge amount of coolant.
PostPosted: Sun Feb 11, 2018 12:45 am
Thanks for the reply, with regards to you questions
I don't have any problems with the heaters, also the rad does (warm up) to operating temperature all over
I know it cant be ruled out, but the water pump is also quite new 10k miles
I did have a issue with the coolant level dropping under the marker on the (bottle/tank) so maybe this
has caused a failure in the sensor?
also per my last post, is the sensor ST205 specific? or will any 6 gen part do
ive recently flushed the coolant in the rad, so this can be re-done when fitting the replacement sensor
PostPosted: Sun Feb 11, 2018 10:37 am
I'd be very surprised if the GT4 sensor is different but I can't say for certain.
If it were me, I'd be ringing TCB to order a new one, then it will be right. www.tcbparts.co.uk
PostPosted: Sun Feb 11, 2018 1:00 pm
If it were me, I'd be ringing TCB to order a new one, then it will be right. http://www.tcbparts.co.uk
Thanks, the sensor does seem to be the route of the problem
unfortunately having a serious issue with buying non fitting brake parts from TCB
and my dealings with Paul, I vowed never to spend another penny there, which is a shame
as ive spend ££££ with them in the past and always found trevors service to be 100%
so ill be looking elsewhere
