It is currently Sun Apr 28, 2024 7:11 pm
PostPosted: Sat Oct 26, 2019 10:15 am
It's time for Mel to have some replacement speakers as she only had 2.5 working when we met 3 years ago. Now she's down to 1.25 ish.
We're off to an audio specialist for a chat/advice/demo this afternoon.
Am I right in thinking the rears are 8" ?
I've measured one in the past, but I have a goldfish memory.
I really need help with the size of fronts. I'm sure they're an odd size, again I vaguely remember discussions on the old GT4OC about mods to get replacements to fit.
It's persisting down here in Belper so I really don't want to have a front door card off. :roll:
MelC is a red 1993 JDM ST205
May the fours be with you.
PostPosted: Fri Nov 22, 2019 5:00 pm
The front speakers are spaced out of the door with plastic mounts - you can fit 6.5" speakers directly into these enclosures no problem; with only some minor trimming of plastic if necessary. The discussions was probably regarding fitting larger sizes, but it's really not necessary IMO. If you have the system with 3 speakers on each door these lower woofers will be larger & I don't know what size is a direct fit - probably around 8".
From memory there's 2 sizes of rear speaker depending on what sound system the car came with - standard rear fill one s & larger 'subwoofers' with an enclosed black plastic box.
PostPosted: Fri Nov 22, 2019 10:12 pm
Thanks for this. The car is in for paint at the moment so I can measure them all up and get replacements sorted as the door cards are off anyway.
Cheers.
Users browsing this forum: No registered users and 180 guests
