It is currently Mon May 06, 2024 10:59 am
 Post subject: engine antifreez
PostPosted: Sun Nov 22, 2015 12:57 pm
Can anyone tell me if blue antifreez is ok to use on my gt4...205?
Usually use green on my vw' s.. not sure for the celica....
 Post subject: Re: engine antifreez
PostPosted: Sun Nov 22, 2015 12:59 pm
I would only use the Toyota for life coolant which is red in colour.
PostPosted: Sun Nov 22, 2015 1:08 pm
Just to be sure... can I use this for the engine? I have the toyota coolant for the CC. Just want to make sure engine and rad have antifreez
PostPosted: Sun Nov 22, 2015 5:11 pm
From experience seeing inside engines and other plumbing from various gt4's, the ones with the red forlife have very little corrosion. Anything else looks like it's been at the bottom of the sea for a decade.
If you can, wait for forlife. If not, blue is probably better than tap water but I would flush & change it ASAP.
PostPosted: Sun Nov 22, 2015 11:21 pm
Yes the same stuff goes in the engine as in the chargecooler.
Also echo Chris's comments - use the red unless no other option.
