Another project http://gt4dc.co.uk/forum/viewtopic.php?f=2&t=7460 |
Page 1 of 6 |
Author: | dt4 [ Fri Sep 18, 2015 8:32 pm ] |
Post subject: | Re: Another project |
Its not showing any fault codes in fact the engine management light doesnt come on at all Turning the key just results in a rapid clicking which I cant tell if it a relay opening and closing or the starter motor, any thoughts |
Author: | NoGT4 [ Fri Sep 18, 2015 8:40 pm ] |
Low battery causing the starter motor to not engage would be my first guess, or bad connection.? Sent from my SM-G928F using Tapatalk |
Author: | Nibbles [ Fri Sep 18, 2015 10:05 pm ] |
Rapid clicking = duff battery. A jump starter pack / jump leads won't provide enough current if the battery has gone open circuit. No engine light = bulb removed, ECU or EFI fuse gone or ECU faulty / removed. |
Author: | dt4 [ Fri Sep 18, 2015 11:11 pm ] |
Thanks both, was leaning towards a new battery first |
Author: | dt4 [ Fri Sep 18, 2015 11:12 pm ] |
Best check the ecu and fuses as well then, thanks chris |
Author: | dt4 [ Sat Sep 19, 2015 7:47 pm ] |
Author: | dt4 [ Sat Sep 19, 2015 7:49 pm ] |
Author: | dt4 [ Sat Sep 19, 2015 7:50 pm ] |
Came with a few bonus parts |
Author: | dt4 [ Sun Sep 20, 2015 8:53 pm ] |
So, I have checked the distributor cap, rotor arm, plugs and leads and put a new battery on. It fires and splutters and on 2 occasions has started for a few seconds before stalling due to low revs, I tightened up the throttle cable a little to lift the starting rpm and the car ran for a minute before cutting out as I slackened off the cable. I haven't been able to start it again although it does turn over and fire Thoughts? Cheers |
Author: | Nibbles [ Sun Sep 20, 2015 10:08 pm ] |
I would say the next step is to replace the engine light and check error codes. Being a 185, I'd most suspect a hole / leak in the air plumbing, quite likely in the corrugated pipe from AFM to turbo. |
Author: | dt4 [ Mon Sep 21, 2015 9:25 am ] |
This may sound really daft! The turbo / air intake pipe as mentioned above is knackered and is cracked / holed. Would that result in the inability to idle due to the AFM not picking up any air being drawn in? |
Author: | Nibbles [ Mon Sep 21, 2015 6:21 pm ] |
dt4 wrote: This may sound really daft! The turbo / air intake pipe as mentioned above is knackered and is cracked / holed. Would that result in the inability to idle due to the AFM not picking up any air being drawn in? Indeed it would. Tank (/gaffer/duct) tape is a usable temporary 'get you home' bodge to prove a point. |
Author: | dt4 [ Mon Sep 21, 2015 8:14 pm ] |
A temp repair wont do for this one I dont think it more or less crumbled when I took it off |
Author: | dt4 [ Thu Sep 24, 2015 8:38 pm ] |
Well there is fuel getting through, I took the fuel supply pipe off the top of the fuel filter and it pumped fuel out when I turned it over |
Page 1 of 6 | All times are UTC + 1 hour |
