I am at my wits end trying to locate this noise. Replaced wheel bearing, checked brake pads, I even wound in the pistons so the pads were not touching the disc but still getting the noise. One thing I did notice is that my power steering pump is leaking so maybe that could be causing the noise although I can not replicate the noise while stationary.
It only happens while moving and happens at around 3k RPM. The noise gets faster as you go through the gears but always starts at 3k RPM.
I have tried to capture the noise but my phone has trouble picking it up over engine noise.
https://youtu.be/reLS5z4Zmbk
