It is currently Mon Jun 03, 2024 11:57 am
 Post subject: Gearbox oil
PostPosted: Sun Jan 04, 2015 1:45 pm
What's currently recommended for the GT-four?
I believe the original fill was as follows:
Category: Gear Oil.
Product Name: TOYOTA GEAR OIL SUPER GL-5 75W-90.
Part No: 08885-02106
API: GL-5
SAE: 75W-90
Type: mineral
As I understand it, it was designed in a time before EP (Extreme Pressure) lubricants were required.
The Toyota repair manual merely states a GL-5 75w-90. Pretty much all GL-5 now available is semi/fully synthetic and EP.
Does anyone know the modern equivalent of a 1995 spec GL-5 oil?
I have read about people having shifting/synchro issues when using modern fully synthetic lubricants, some using ATF, some mixing in LSD additives & claiming it helps, some using GL-1 mineral (good for synchros, bad for gears?) it's all a bit confusing really.
Other considerations - Does anyone know what the synchros are made of? If they are a yellow metal (brass/copper) I believe some oils can cause corrosion.
 Post subject: Re: Gearbox oil
PostPosted: Sun Jan 04, 2015 7:55 pm
My opinion is that most of the problems are caused by poor use of the gearbox and infrequent oil changes.
I have been using Millers CRX 75W90 NT in my gearbox for over 100k miles. The gearbox still performs well with over 150k miles on the clock.
PostPosted: Mon Jan 05, 2015 4:31 pm
Have changed oil twice on my gearbox, once when got car at 132,000 miles and the just I did a clutch at 199,500 miles. I will be doing again soon as currently my CS is on 299,635 miles still the original box :-)
Sent from my HTC One using Tapatalk 2
Darryl
Users browsing this forum: No registered users and 15 guests
