It is currently Mon Apr 29, 2024 9:24 am
 Post subject: Checking cam timing
PostPosted: Mon May 05, 2014 4:06 pm
Hi just a quick question. I was just wondering how I go about checking my cam timing? What is the easiest way to make sure one of my cams isn't of by a tooth?
Thanks
 Post subject: Re: Checking cam timing
PostPosted: Mon May 05, 2014 4:31 pm
For 185 or 205, you can check the cam end by removing the upper cam belt cover. There is a dot on 1 spoke of each cam wheel, Mark the tooth on the pulley adjacent ( I use tippex) and use this tooth against the ridge at the top of the backplate behind as the marker.
On 205 (Don't think 185's have this) you can alternatively remove chargecooler, throttle body and cam cover. You can then see a notch at the top of the front cam bearing for each cam, and the cams also have notches. These marks are more accurate than the ones on the pulleys as you are not liable to get parallax error.
Either way, rotate the crank pulley clockwise with a 19mm socket until the mark on the crank pulley lines up with the 0 mark. If the marks on the cam are 180 degrees out, then rotate the crank another turn and then line up the mark again.
The marks on the cams/pulleys should now line up with the fixed marks.
PostPosted: Mon May 05, 2014 6:11 pm
Thanks mate I'm sure il understand when I get the cam belt cover off. I was just asking as on an mx5 (which was my last car) it was common knowledge how many belt teeth should be between the marks on each cam pulley at tdc which gave a quick easy way to double check it was correct.
Thanks mate
PostPosted: Tue May 06, 2014 1:05 pm
Can confirm the 185 also has those notches on can and the can bearing caps.
Darryl
Darryl
Users browsing this forum: No registered users and 182 guests
