It is currently Mon Oct 06, 2025 2:08 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Part Number List
PostPosted: Tue May 06, 2008 12:31 pm
Thought I would start a thread for all to add part numbers and costs to as a reference source all will then be compiled and made a tech doc/sticky :-
Model, Category, Description, Part Number, Cost,
St205, Brakes, Front Brake Caliper Pins, 90240-06019,
ST205, Brakes, Front Anti-Rattle Spring, 47748-14080,
ST205, Brakes, Front Pin Retaining Clip, 90468-12022,
St205, Brakes, Rear Brake Caliper Pins, 90240-06017,
ST205, Brakes, Rear Anti-Rattle Spring, 47748-14090,
ST205, Brakes, Rear Pin Retaining Clip, 90468-12020,
PostPosted: Tue May 06, 2008 7:01 pm
ST205 gearbox exhaust hanger bracket, 17571-74221
ST205 front caliper overhaul kit, 04479-20260
knock sensor, 89615-20060
PostPosted: Tue May 06, 2008 7:50 pm
St205 & St185 Oil Filter (Made in China) 90915-YZZJ2
St205 & St185 Sump Plug Gasket 90080-43037
St205 Injector Insulator (rubber O ring - 2 per injector) 23291-75010 £0.46
ST205 Injector Insulator 23291-88480 £3.94
PostPosted: Thu May 08, 2008 12:52 pm
St205 & st185 REAR DIFF MOUNT CUSHION 52291-20010
2004 Subaru WRX
PostPosted: Thu May 08, 2008 1:22 pm
Good call!
PostPosted: Fri May 09, 2008 10:04 am
St 185 rear drop link 48830-20010
St 185 rear drop link nut 90179-10054
Longlife coolant 08889-80002
St 185 Front n/s hub Assembly 43502-20100
St 185 cs/rc Front bumper lower grille 53102-20030
St 185 Ht Lead set (5mm) 90919-21524
St 185 Distributor Cap 19101-88364
St 185 Rotor Arm 19102- 74040
St 185 Knock Sensor 89615-50010
2004 Subaru WRX
PostPosted: Thu May 22, 2008 8:34 am
Anyone have the part numbers for the st205 Distributor Cap and rotor arm.
EDIT, I found these part numbers in the EPC.
Cap 19101-88460, rotor 19102-74040
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Thu May 29, 2008 10:20 pm
My contribution - I started a list a couple years ago, sorry for the slightly jumbled layout its from an excel table.
Please check these part numbers before ordering with them! :)
Model Description Part Name Part Number Price Notes Link to Picture
ST185 Thermostat THERMOSTAT 90916-03075 13.87 *2 versions??
ST185 Thermostat Gasket GSKT, WATER OUTL 16325-62010 4.06 *2 versions??
ST205 IC Badge PLATE, ENGINE SP 11286-88480 4.50
ST205 Bonnet Vent Grille PLATE, BULGE 76190-20010 23.71
ST205 Parcel Shelf Clip CLAMP, PACKAGE TRAY 64324-20051-22 5.05
ST205 Parcel Shelf Clip BRACKET, PACKAGE TRAY 64323-20061-22 4.61
ST205 100A Main Fuse FUSE 90982-08246 9.35
ST205 Thermostat THERMOSTAT 90916-03100 13.85
ST205 Thermostat Gasket GASKET, HOUSING 16325-63011 1.06
ST205 Front Top Mount Nut NUT 90179-10095 1.06
ST205 Chargecooler to Throttle body connector CONNECTOR, INTAK 17861-88480 22.92
ST205 Hydraulic Tensioner TENSIONER ASSY 13540-88480 39.22
ST205 Pulley IDLER, S/A, TIMIN 13505-88480 71.26
ST205 Oil Pressure Regulator REGULATOR 15310-88460 18.44 ??
ST205 Gasket for Oil Pressure Regulator GSKT, OIL REG 15318-88460 3.03 ??
ST205 Gearbox Drain/Fill Gasket GASKET 90430-18008 1.23
ST205 Rear Differential Drain/Fill GSKT. DRAIN PLUG 12157-10010 1.80
ST205 Rear Anti-Roll Bar Droplink LINK ASSY, RR STABILI 48830-20010 33.07
ST205 Front/Rear Anti-Roll Bar Droplink Nuts NUT 90179-10183 0.59
ST205 Figure 8 - Camber Link ARM SUB-ASSY, CAMBER 48066-20061 60.00 TCB
ST205 Tie Rod - Number 1 Arm - RHS ARM ??? 48068-29195 130.00 TCB
ST205 Tie Rod - Number 1 Arm - LHS
ST205 Track Control Arm - Number 2 Arm RHS ARM SUB-ASSY 48605-29025 210.00 TCB
ST205 Track Control Arm - Number 2 Arm LHS ARM SUB-ASSY 48606-29025 210.00 TCB
ST205 Rear Suspension Strut to Hub Bolt BOLT 90105-15001 2.06 90105-15001
ST205 Rear Suspension Strut to Hub Nut NUT 90179-15001 2.88 90179-15001
ST205 Split Pin COTTER PIN 95381-03025 0.28 95381-03025
ST205 Nut Cap CAP FR WHEEL 43525-20050 1.10 43525-20050
ST205 Nut Front Strut to Fig 8 NUT 90179-16027 1.04 90179-16027
ST205 Nut Front Hub to Lower Arms NUT 90171-14007 0.85 90171-14007
ST205 Nut Fig 8 to Lower Arm NUT 90179-16027 1.04 90179-16027
ST205 Tie Rod Collar/Bush COLLAR/BUSH 90389-21003 2.60 90389-21003
ST205 Track Control Arm Bolt BOLT 90119-14084 2.96 90119-14084
ST205 Tie Rod Bolt BOLT 90119-14052 2.68 90119-14052
ST205 Rear Topmount Nuts NUT 90179-08122 2.41 90179-08122
ST205 Rear Brake Pin Clip CLIP 90468-12020 0.46 90468-12020
ST205 Rear Brake Rattle Spring SPRING, RATTLE 47748-14090 4.39 47748-14090
ST205 Rear Brake Pad Pin PIN 90240-06017 0.93 90240-06017
ST205 Coat Hook HOOK, COAT 74631-20060-22 4.36 74631-20060-22
ST205 Rotor Arm ROTOR, ASSY 19102-74040
ST205 Spark Plug SPARK PLUG 90919-01180
ST205 Distributor Cap CAP ASSY, DISTRIBUTO 19101-88460
ALL Toyota 'For-Life' Coolant 04C0702 COOLANT 08889-80002 13.00
ST185/ST205 Oil Filter OIL FILTER 90915-10004 7.78
ALL Sump Plug Gasket GSKT, DRAIN PLUG 90430-12028 1.22
ST205 Rear Brake Disc DISC RR 42431-20280 69.00 CTP
PostPosted: Mon Jun 16, 2008 6:52 pm
Whats the part numbers for the plug wires (leads)? I am using an old part catalog and toyota tells me the numbers I gave them are wrong.
PostPosted: Wed Oct 01, 2008 11:47 am
All for ST205
Fuel Pump Bracket, 23206-74760
Gasket for fuel pump bracket, 77169-14010
Rear Brake anti-rattle clips (top of caliper) 04948-14010
Rear handbrake shoe, NS, trailing 46590-33020
Handbrake mechanism lever, NS, 47612-20030
rear caliper overhaul kit, 04479-20270
Piston, rear - 47731-20230
Differential ring gear backlash adjustment washer, 2.52mm, 90201-54011
 Post subject: Light Bulbs
PostPosted: Thu Oct 02, 2008 8:42 pm
I'm cheating :oops: ...follow this link for a light bulb application guide.
http://www.eautoworks.com/html/bulbSearch-1995-Toyota-Celica.htm
Vice Chairman
PostPosted: Mon Oct 20, 2008 5:50 pm
More ST205 numbers
Plug leads - 90919-21578, comes with plastic tray.
V-band Clamp for WRC anti-lag valve 17229-74010
Bolt for above 91611-60640
Chargecooler Mounting Bushes 90385-09001
Cam cover washers 90210-06013
PostPosted: Tue Oct 21, 2008 7:42 pm
Drivers side heated mirror - 87931-2B800
Passenger side - ??????? anybody
98 Celica GT4 ST205
Full forged rebuild with Wiesco pistons, Crower rods, mildly ported head, 264/272 HKS cams, FMIC, PFC Pro, GT35 BB turbo, turbo back 3" system.
Currently running 1.6bar/520+bhp
PostPosted: Tue Oct 21, 2008 9:00 pm
Heated?? Not seen those I don't think. Good find.
PostPosted: Sat Nov 08, 2008 5:53 pm
Fuel injector seals courtesy of jeff rosie.
T23291-75010 8 off £0.54 each
T23291-88480 4 off £4.78 each
Users browsing this forum: No registered users and 16 guests
