It is currently Tue Oct 07, 2025 5:54 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
 Post subject: need help car wont start
PostPosted: Sun May 20, 2012 7:55 pm
finally fixed my getting the water temp sensor started the car up for the first time in 6-8 months with fuel in it standing over this period car started bit of smoke told oil might be on the seals as it was black and not to worry just let it idle went back to the car to start it and let it idle however car wont start now could this be stagnant fuel or something i just havnt put me finger on have check for error codes and none showing im a little lost and in need of help :shock:
:) sketch :)
PostPosted: Sun May 20, 2012 8:24 pm
Do the usual checks - check for sparks?
Does the exhaust smell of fuel ?
Have a quick look at this thread, might be worth popping the lid off your ecu and see if the capacitor has gone as shown.
http://gt4dc.co.uk/forum/viewtopic.php?t=5617
PostPosted: Sun May 20, 2012 8:53 pm
got everything only thing it might be is old fuel and low on fuel been told to try putting more in and see if it starts then
:) sketch :)
PostPosted: Sun May 20, 2012 9:46 pm
Has it got an aftermarket alarm or immobiliser on it?
PostPosted: Sun May 20, 2012 10:28 pm
yer but that seems to be fine
:) sketch :)
PostPosted: Mon May 21, 2012 10:24 am
Hey,a mate of mine had his motorbike off the road over the winter and when he came run it last month and wouldnt start.drained tank and refilled fuel, started 1st time.turns out nowadays fuel has a shelf life off 3-4 months before starting to degrade.seems weird to me but it changing the fuel worked, maybe worth a try.keep the fuel though and mix it in small quantities over time with good fuel! :o
PostPosted: Mon May 21, 2012 5:25 pm
thanks will be doing this hopfully the weekend fingers crossed
:) sketch :)
PostPosted: Sat May 26, 2012 5:40 pm
right car still wont start smell of fuel allmost fires trys but wont run stuck now as ive changed everything on it
:) sketch :)
PostPosted: Sat May 26, 2012 6:19 pm
Can you give us a list of everything you've changed?
Looking back at the first post - when you changed the water temp sensor and then started the car did it actually start?
You post seems to suggest that the car started and then didn't start the 2nd time? Is that correct?
PostPosted: Sat May 26, 2012 6:22 pm
yer it started the first time with black smoke turned it off as wasnt sure what this was found out unburnt fuel tried starting again wouldnt start in total in the last 6 months it has had e.c.u change readed no faults a new fuel pressure regulator new afm and water temp sensor
:) sketch :)
PostPosted: Sat May 26, 2012 6:25 pm
what about spark plugs, distributor cap, rotor arm, coil, leads?
Have you checked for spark?
PostPosted: Sat May 26, 2012 6:26 pm
sorry all changed and had spark car tried to fire and was lumpy but then cut out
:) sketch :)
PostPosted: Sat May 26, 2012 6:52 pm
So it's turning over but just not igniting?
1998 mercedes E280- sold
PostPosted: Sat May 26, 2012 7:04 pm
correct strong smell of fuel from exsaust just checked
:) sketch :)
PostPosted: Sat May 26, 2012 7:08 pm
Try bumping it.....??
