It is currently Sat Oct 11, 2025 11:50 pm
PostPosted: Sat Mar 27, 2010 3:38 pm
Just a heads up/query
When people have had engines out have they inspected the main wiring loom
There's a large plastic encapsulated section which sits over the 'box right next to the breather
I've noticed this is has always been a bit claggy on mine in this neck of the woods and I assume most are the same
However, this morning's joyous job was to clean it up ready for refit. I decided that since all the loom taping is failing and I had a couple of tweaks in mind I'd peel this section back to bare wires. Some/most of my wire tucking plans have bitten the dust as I ran into a serious lack of boverred when doing the loom after cleaning up this mess
However, rambling aside, I did I found some disturbing stuff. The wiring on mine shows heavy contamination with oil and grit. This seems to have led to stiffening/degredation of the wire casings themselves :(
I've had to replace a couple which had visibly cracked sheathing too and have cleaned everything up again
If you're in that neck of th woods PITA thiugh it may be I'd suggest a cursory inspection (It's not trivial however :( ).
Rather annoyingly I've just had one of those cut Vs delete senior moments with the camera memory card :( so there's no pictures. It wasn't that exciting anyway as I don't have a macro mode for close up stuff :lol:
Incidentally, can anyone think of a reason not to redirect the breather?
I'm thinking of a bit of hose down to the general vicinity of the steering rack where it can belch fumes to it's hearts content without causing further issues
PostPosted: Sat Mar 27, 2010 5:25 pm
With the looms I've worked on the combination of old age/heat/oil has resulted in hardening of the insulation and associated plastic connectors and sheaths. Particularly annoying when its the injector plugs that break :(
Users browsing this forum: Google Adsense [Bot] and 5 guests
