Mixture Setting Up http://gt4dc.co.uk/forum/viewtopic.php?f=2&t=3183 |
Author: | Exup [ Fri Sep 04, 2009 9:49 pm ] |
Post subject: | Mixture Setting Up |
Can anybody tell me how do you set the air flow mixture up on a St185. My Celica appears to be running a bit rich. |
Author: | Nibbles [ Fri Sep 04, 2009 10:52 pm ] |
If it's a 185 they normally do run rich. For idle & cruising it should automatically run closed loop from the lambda sensor and will be fairly accurate. You shouldn't attempt to tweak the AFM unless you have a wideband sensor & gauge. If you go too weak on boost you'll blow the engine - especially if you have a top mount air to air intercooler as you will have high charge temperatures as well. |
Author: | Exup [ Sat Sep 05, 2009 8:25 am ] |
Thanks for your help. ![]() Chris-de-Bear wrote: If it's a 185 they normally do run rich.
