It is currently Sat Oct 11, 2025 5:49 am
 Post subject: Mixture Setting Up
PostPosted: Fri Sep 04, 2009 9:49 pm
Can anybody tell me how do you set the air flow mixture up on a St185.
My Celica appears to be running a bit rich.
Exup
PostPosted: Fri Sep 04, 2009 10:52 pm
If it's a 185 they normally do run rich.
For idle & cruising it should automatically run closed loop from the lambda sensor and will be fairly accurate.
You shouldn't attempt to tweak the AFM unless you have a wideband sensor & gauge. If you go too weak on boost you'll blow the engine - especially if you have a top mount air to air intercooler as you will have high charge temperatures as well.
PostPosted: Sat Sep 05, 2009 8:25 am
Thanks for your help. :wink:
Exup
