It is currently Wed Oct 08, 2025 1:47 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jun 14, 2012 8:46 am
injector could be stuk open?
PostPosted: Thu Jun 14, 2012 10:30 am
I would suspect injector stuck open, but could be a fault in wiring or ECU rather than injector itself.
PostPosted: Thu Jun 14, 2012 12:43 pm
injector is fine so guessing e.c.u do have a spare so fingers crossed
:) sketch :)
PostPosted: Thu Jun 14, 2012 1:12 pm
Hope so, sure it will be! if it isn't could a false input into it cause over fuelling?maf/map sensor or anything else? I'm not smart enough! :P
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Thu Jun 14, 2012 1:21 pm
no idea changed that much stuff on it now im running out of ideas but fingers crossed the specialist can sort it out
:) sketch :)
PostPosted: Thu Jun 14, 2012 4:30 pm
had some good news the afm was jammed and the lambda sensor needs replacing any1 know where i can get 1 from cheap
:) sketch :)
PostPosted: Thu Jun 14, 2012 5:16 pm
TCB
Last on I bought recently was about £50 new (4 wire)
You will need to check how many wires are on the sensor, there are 1, 3 or 4.
PostPosted: Thu Jun 14, 2012 6:13 pm
4 on there where did you get that from being quoted £151 from toyota and 73 from a factors
:) sketch :)
PostPosted: Thu Jun 14, 2012 7:58 pm
tcbparts.co.uk
PostPosted: Thu Jun 14, 2012 8:03 pm
lambda sensor 4 wire (UK) or single wire (JDM) ? https://www.sapmotorparts.com
ST165 turbo 4WD
PostPosted: Thu Jun 14, 2012 8:21 pm
its a jap import so jdm i asume but thats perfic thanks
:) sketch :)
PostPosted: Thu Jun 14, 2012 10:56 pm
A JDM car with a 4 wire lambda sensor. Doesn't sound right to me.
PostPosted: Fri Jun 15, 2012 8:32 am
nope but picking car up today i hope so will check it and then buy corrct to be on safe side
:) sketch :)
PostPosted: Fri Jun 15, 2012 11:41 am
I bought one from SAP a few years back, was a generic one with a rather flimsy adapter plate which cracked & broke in no time.
Recently bought the pattern part one from TCB which looks ok.
http://www.tcbparts.co.uk/
Lambda Sensor (4 wire type) Outside make of Excellent Quality
Fits Celica ST 205 GT4 (3S-GTE engine), ST 185 GT4
ST 202 2.0 3S-GE engine (up to 1995)
MR2 Mk2 Turbo Rev 3 3S-GTE engine also N/A 3S-GE engine (up to 1995)
If your model isn't listed please call for further information
Part number: TCB
Special Offer Price £57.00 + vat
Of if you're fussy.
Lambda Sensor Genuine Toyota
Fits Celica ST 205 GT4 (3S-GTE engine), ST 202 3S-GEengine, ST 185 GT4
& MR2 Mk2 Rev3 Turbo (1993-1999) & 3S-GE engine (1993-1997)
Part number: 89465-29725
Normal Price: £128.43 + vat
Special Offer Price £92.35 + vat while stock last
PostPosted: Sun Jul 01, 2012 8:13 pm
do you know how the AFM was repaired or was it replaced?
