hi only me http://gt4dc.co.uk/forum/viewtopic.php?f=16&t=3071 |
Author: | nikkin [ Fri Jul 10, 2009 3:02 pm ] |
Post subject: | hi only me |
Hi guys and girls been away for a while as the old cs has been off the road. just got her back up and running almost 100% running 1.5 bar boost and getting 326 bhp and 352 lb/ft torque the problem im having is turdo compression surge on part throatle Floor it and its ok try to build the revs up slowishl and it compression surge. Has anyone come across this before and what did you have to do to stop it the turbo builds say trim back the blades fensport says its turbo problem but i find it hard to believe it dont do it whenflooring the car only on paert throatle could do with some advice here if pos, just cost just over a grand to have it back on the road and now its seems its going to take anoougher monkey to cut back on what i have for those you dont know me or forgot i have a red st 185 cs full internal upgrade off market ecu stage 3 turbo blah blah blah im sure you get the picture oh it still has the liquid cooled intercooler thks peep |
Author: | two_OH_five [ Fri Jul 10, 2009 4:53 pm ] |
are you running a straight intake? |
Author: | Diceman [ Fri Jul 10, 2009 5:19 pm ] |
Whose turbo is it? What specification is the turbo? (ideally need the trim of the compressor wheel and any "hybrid mods"). As steve says - do you have a straight air intake and a low pressure drop filter? |
Author: | nikkin [ Sat Jul 11, 2009 9:02 am ] |
yes straightish intake still have battery in the norm place but no afm anymore turbo is a stage 3 modded norm gt4 turbo not sure of trim mods are full engine rebuild with forged pistons aussie dp mongoss exhaust removed afm nemisis ecu and recirculating dv will try to source the trim |
Author: | TrackToyFour [ Sat Jul 11, 2009 2:33 pm ] |
Do you know who built the hybrid turbo? A hybrid can have different work done on it such as a different turbine wheel, compresser wheel, wastegate porting, twin entry porting. Stage 3 can mean different things depending on who built the turbo. e.g. Owen Developments Stage 3 Hybrid CT20b/CT26 would be different from a Turbo Dynamics Stage 3 Hybrid CT20b/CT26 HKS turbos often have an anti-surge compressor intake design and you can modify a Garrett in the same way. I'm not sure I've ever seen a Toyota compressor housing being modified in this way. It may well be that there is insufficient 'meat' in the casting to allow this. In other words your options in this area may be limited if your hybrid is based on the Toyota casting. |
