It is currently Sun May 19, 2024 5:32 pm
 Post subject: Double Din in ST205
PostPosted: Sun Jan 03, 2016 6:00 pm
Do I need a facia for it or will it sit nicely in the current aperture?
 Post subject: Re: Double Din in ST205
PostPosted: Sun Jan 03, 2016 6:37 pm
Depending on the design it will fit however the dash design means that usually there is nowhere for the trim that is generally supplied with a head unit to go - a bit difficult to explain really. The OEM double din headunit essentially fitted behind the plastic but flush with it.
PostPosted: Sun Jan 03, 2016 7:00 pm
Looking at getting one of these - just something to stream music from iPhone and do handsfree calls http://www.amazon.co.uk/Kenwood-DPX-306 ... B00T3URT0W - seems to have decent clearance around the edge?
PostPosted: Tue Jan 05, 2016 10:00 am
JVC KW-20BT on the way...will fit it with my new dashcam at the weekend :-)
PostPosted: Tue Jan 05, 2016 6:40 pm
What dashcam did you go for?
PostPosted: Tue Jan 05, 2016 8:21 pm
I just bought a cheap G1WH to get me started, seems like the cheapest you can go for that actually works as you need. Will install and trial it and post up a video over the weekend (assuming it arrives!)
