Cracks in turbo housing internals http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=7524 |
Author: | NoGT4 [ Sat Dec 05, 2015 9:14 pm ] |
Post subject: | Cracks in turbo housing internals |
Just put my old turbo housing through the parts washer after stripping it down, and found cracks internally. See pics Is this common, or a cause of potential failure? Sent from my SM-G928F using Tapatalk |
Author: | TrackToyFour [ Sat Dec 05, 2015 10:41 pm ] |
Post subject: | Re: Cracks in turbo housing internals |
I've heard reports of the TTE inconel turbine housing failing in spectacular (and expensive) fashion. I guess if your turbo has seen high boost and/or experienced some sort of thermal shock then it could result in cracking? As a matter of interest, what was your intention with this turbo by stripping it? They're not exactly the sort of component you can rebuild yourself! |
Author: | NoGT4 [ Sun Dec 06, 2015 12:07 pm ] |
Just planning to get it rebuilt so thought I'd strip it down and clean the casting. There is about 8 cracks in total, and if a piece comes off all bets are off. Sent from my Sony Xperia Tablet |
Author: | TrackToyFour [ Sun Dec 06, 2015 4:10 pm ] |
Sounds like it's only fit for the skip Phil. I think JP has a secret stash of turbos if you need a rebuild candidate |
