Whine from 185 http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=7513 |
Author: | audiodjmp77 [ Tue Nov 17, 2015 9:41 pm ] |
Post subject: | Whine from 185 |
Just bouncing an idea about, but I hear a whine sounding like it has a straight cut box when I'm using slight throttle, but goes when I use more or come off the throttle. I'm hoping that its the diff, not the gearbox on its way If it is the box, would a 205 box bolt straight on, and is it a stronger one than the 185 one ? |
Author: | BecauseRaceCar [ Thu Nov 19, 2015 1:06 am ] |
Post subject: | Re: Whine from 185 |
Had a similar issue turned out to be rear droplink dislocated slightly and caused rubbing on wheel, coilover had twisted loose from a B road thrashing. Sounded like an alternator whine or very quiet diff whine. Fixed with a socket set, coilover spanner and a rubber hammer. Could be unrelated, but thought I'd float the idea in case you have trouble diagnosing it. Best to get it up in the air and have a poke round. "05 box can fit I think, maybe an adaptor needed. |
Author: | Sirius [ Thu Nov 19, 2015 7:16 pm ] |
The ST205 box should fit and is generally considered to be a 'stronger' box. The only issue I am aware of is the speedo drive - some are electronic and some mechanical, this will need swapping from your old box. |
Author: | audiodjmp77 [ Thu Nov 19, 2015 8:56 pm ] |
Cheers for that fellas. I'll have a look and see. |
