http://gt4dc.co.uk/forum/
Charge cooler
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=7471
Author:  Johnpaul110 [ Mon Sep 28, 2015 4:59 pm ]
Post subject:  Charge cooler
Put a second hand charge cooler on I can feel it buzzing in pipes but there's no movement in charge cooler Evan when I Rev it to get it to start would I have the pipes on wrong way cheers
Author:  TrackToyFour [ Mon Sep 28, 2015 9:52 pm ]
Post subject:  Re: Charge cooler
If you have fitted a second hand charge cooler pump was it a reconditioned item or sourced from a breakers yard?
If the pump is working properly you should see the charge coolant swirling when you rev the engine. If not, then either there is an air lock in the hoses or the pump isn't functioning.
Author:  Johnpaul110 [ Tue Sep 29, 2015 1:43 pm ]
Got it of a breaker he sed it's a good one but no reconditioned how would you check of air lock I should of left it in the garage lol
Author:  **BETSY** [ Fri Oct 23, 2015 6:49 pm ]
What was wrong with your old pump, noisy?
As mentioned above the fluid level should drop slightly when the pump kicks in.
Any error codes?
Author:  Johnpaul110 [ Tue Nov 10, 2015 9:30 pm ]
Ye old pump was realy noisy you can feel it vibrate but not pumping not movement in charge cooler
Author:  **BETSY** [ Tue Nov 10, 2015 11:33 pm ]
Any error codes?
Author:  Johnpaul110 [ Wed Nov 11, 2015 12:15 am ]
I'll find out 2mara get back to ye
Author:  **BETSY** [ Tue Mar 01, 2016 9:16 am ]
How did you get on with this?
