window washers not working correctly http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=7283 |
Author: | jdm-gt4 [ Wed Jan 28, 2015 5:07 pm ] |
Post subject: | window washers not working correctly |
hi i woundered if anyone could help with regards to this, my window washers seem to have stopped working properly i can hear the pump but the jets just dribble out a little water (one does the other doesnt) so im assumeing the jets may be blocked? anyone got a check-list of things to try/check and if it is jets maybe? blocked, could i take them off and soak them in something to give them a clean? |
Author: | Nibbles [ Wed Jan 28, 2015 7:07 pm ] |
Post subject: | Re: window washers not working correctly |
Use a sewing pin to poke down the holes to clear them. Since that only pushes the dirt back into the pipes, it's worth pulling the pipes off the back and reverse flushing the nozzles (and run the pump to run the dirt out of the pipes). If you have dirt in the washer bottle, this will become a routine unless you manage to find an in-line filter to fit. |
