It is currently Sun Oct 05, 2025 7:33 pm
 Post subject: stock ecu map
PostPosted: Fri Apr 25, 2014 10:20 am
anybody have any idea what this is a map of?
data extracted from stock rev3 ecu.
x and y data (0-14 and 0-8) were made up by me.
edit:- interpreted slightly differently
St205 WRC - Running sweet.
 Post subject: Re: stock ecu map
PostPosted: Fri Apr 25, 2014 6:59 pm
Looks like the stock ignition map.
RPM left(low) to right(high)
Manifold pressure back (vac) to front (boost)
Advance bottom(zero) to top(40 degrees ish)
PostPosted: Fri Apr 25, 2014 7:06 pm
For the 185 AFAIK
PostPosted: Tue Apr 29, 2014 8:08 pm
the 185 map is 15x15 and the 205 is 15x9. what could be the reason for the lower resolution? Also, the values and the span are completely different.
PostPosted: Tue Apr 29, 2014 8:35 pm
The map in the first post is for turbo boost pressure control, it is one of the maps/tables that controls the pulse width of the Turbo VSV. That map is indexed by throttle position on one axis and RPM on the other axis to give a base line pulse width for the T/VSV. There are other maps/tables that alter the pulse width depending on selected gear, intake air temp and manifold pressure.
PostPosted: Tue Apr 29, 2014 8:40 pm
was also looking into the blitz access rom code for the maps but seems pretty well hidden (in hex viewer)
waiting for my hitachi processor plugin to disassemble code in the hope that the map areas become more obvious. In the meantime i did a google search for some maps including blitz ones and few came up on the OC!!! Clicked the links and came up "GT4OC Membership/Trial Expiry Notice" That PI$$ED me off AGAIN! Well done to DC for keeping things free and open (especially when everyone benefits)
The bit that gets me is I probably made some of them posts and now I cant see them! Sod'Em! Oh look, I'm ranting again! lol
PostPosted: Tue Apr 29, 2014 8:44 pm
oh, ok, so its RPM vs PWM for the T/VSV. Interesting. There are other maps but getting long winded as my laptop has excel 2013 and everything is different to what I'm used to on work PC (excel 2010). Typical microsoft selling the same stuff but jiggle everything around to make it look completely new.
PostPosted: Thu May 01, 2014 10:12 pm
I can have a look on the oc im a member on there as well if you want you just need to point me to them
PostPosted: Fri May 09, 2014 12:50 pm
thanks, I'll get by. I'd rather bite my nose to spite my face.
PostPosted: Fri May 09, 2014 3:38 pm
It can only improve the looks :D
PostPosted: Sat May 10, 2014 10:35 am
thanks Chris :P
lol
