http://gt4dc.co.uk/forum/
St185 rear lights
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=7007
Author:  essexgt4 [ Sat Mar 22, 2014 11:27 pm ]
Post subject:  St185 rear lights
 by essexgt4 on Sat Mar 22, 2014 7:17 pm
Right for some reason the rear lights on my other half's185 aren't working recently just converted to rev 3 engine, brake lights work so do indicators and reverse lights, fuses are intact although I don't seem to be getting a reading on voltmeter on connection points, are there any common failures or does anyone have any suggestions?
Author:  Nibbles [ Sun Mar 23, 2014 12:05 am ]
Post subject:  Re: St185 rear lights
If you retained the 185 engine loom then there shouldn't be any wiring issue as a result of the engine change.
Looks like there's a tail light relay and tail light fuse, not sure where they are though.
The following should help diagnose, it shows fuse & relay locations and wiring routes as well as circuit diagrams.
https://dl.dropboxusercontent.com/u/831 ... T185RC.pdf
Author:  essexgt4 [ Sun Mar 23, 2014 5:45 pm ]
Had power to everything but the tail lights ended up running a live feed to the connector pin and hey presto they work, does anyone reckon it could be down to the lamp failure box behind rear passenger trim?
