http://gt4dc.co.uk/forum/
tweaking the ECU :)
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6990
Author:  niblettr [ Wed Mar 12, 2014 12:05 pm ]
Post subject:  tweaking the ECU :)
http://www.twobrutal.co.uk/forum/showth ... VZ-FE-ECUs
Author:  hally [ Wed Mar 12, 2014 2:19 pm ]
Post subject:  Re: tweaking the ECU :)
epic.if you can get these to work lol
id have 1
Author:  GottaGoTurbo [ Wed Mar 12, 2014 6:23 pm ]
I have two st205 ecu's with extra boards already fitted
One has a D151804-7720
The other has a D151804-7720 + a D151804-0471 and a TYS11600 daughter board
These were both removed from running ST205's but I don't know what to do with them, so they have sat in my workshop for a while now.
Any ideas?
Author:  niblettr [ Wed Mar 12, 2014 7:27 pm ]
id have 1
It does work! :P
Author:  Kris [ Wed Mar 12, 2014 10:08 pm ]
ECU specific information ... https://www.assembla.com/spaces/3SGTE_ECU/wiki/MR2_ECU_93_to_99_%28Gen_3_to_5%29
Author:  niblettr [ Thu Mar 13, 2014 11:49 am ]
here is some of the work my mate and I did on the Blitz ecu reverse engineering ;)
https://www.assembla.com/code/3SGTE_ECU ... s/89/blitz
Author:  cms-gt4 [ Thu Mar 13, 2014 9:03 pm ]
If you can alter systems, can you also remove the ecu check for wta ic pump and water level?
Author:  niblettr [ Fri Mar 14, 2014 9:30 am ]
yep, once the disassembled code is fully understood. Even changing injector pulse widths and timings is not out the question.
Author:  niblettr [ Mon Mar 17, 2014 9:00 am ]
Any ideas?
Could you take a picture of the boards and post them up please?? :)
Author:  GottaGoTurbo [ Mon Mar 17, 2014 7:13 pm ]
I haven't got a clue how to do that Rob but if you PM me I can send you lots of pictures of the ecu's
Oops your not Rob (that's Nibbles) you are Chris? Mr D Bear?
Author:  niblettr [ Tue Mar 18, 2014 10:30 pm ]
You were right the first time. I'm Rob, Nibbles is Chris. Ok, i'll PM you my email address. Do you mind if I post up the piccies?
Author:  GottaGoTurbo [ Tue Mar 18, 2014 11:20 pm ]
You can post up the pictures - no problem
Author:  niblettr [ Thu Mar 20, 2014 9:21 am ]
test
https://docs.google.com/file/d/0Bw8i0o4 ... Y5X2s/edit
can people see the above, not too sure about googledrive...
https://googledrive.com/host/0Bw8i0o4iJ ... U0/unnamed (1).jpg
Author:  niblettr [ Thu Mar 20, 2014 9:31 am ]
wow, the "hosting" url link is REALLY buried in there. I think they are not too keen on you hosting images..
