Borg Warner EFR 6258 http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6895 |
Author: | niblettr [ Tue Jan 07, 2014 10:58 am ] |
Post subject: | Borg Warner EFR 6258 |
Right, these turbo are quite easy to get hold of now, so this is a reminder to anyone who is thinking of getting one and post results... lol |
Author: | Sunny [ Wed Jan 08, 2014 10:44 pm ] |
Post subject: | Re: Borg Warner EFR 6258 |
Hi, i'am pretty sure you will be happy with'em greetz |
Author: | niblettr [ Fri Feb 14, 2014 12:04 pm ] |
Will it bolt onto the standard exhaust manifold with an adaptor plate? What adaptor plate is it that one would needs? |
Author: | niblettr [ Mon Feb 17, 2014 11:55 am ] |
Thanks for that. What is the reason for the bolt holes if the plate is being welded on anyway? (sorry if this is a stupid question) |
Author: | Sunny [ Tue Feb 18, 2014 9:20 am ] |
Hi, to mount the tourbine housing greetz |
Author: | niblettr [ Tue Feb 18, 2014 11:06 am ] |
I see (didn't pay attention to the pictures) So the plate is welded to the manifold, studs tapped into the plate to bolt to the turbine housing.. Can the compressor outlet be easily plumbed into the stock charge cooler? |
Author: | niblettr [ Tue Feb 18, 2014 12:57 pm ] |
REALLY must teach myself to weld. I have a welder and done a bit but my work always comes out looking like pigeon guano! (still gets through the MOT though...) Nice heat shield. What material is that? |
Author: | Sirius [ Tue Feb 18, 2014 2:19 pm ] |
The heatshield material looks like Nimbus G2 to me: http://www.demon-tweeks.co.uk/motorsport/heat-shielding-protection/nimbus-gii-heat-shield I have used the same stuff on my car |
Author: | Sunny [ Tue Feb 18, 2014 11:16 pm ] |
Hi, nearly right, G1 greetz |
Author: | Sunny [ Wed Mar 26, 2014 12:23 pm ] |
Hi, just found that http://www.fensport.co.uk/Parts/Model_1 ... ory_1/1943 greetz |
Author: | yellowchinaman [ Tue Aug 05, 2014 7:43 am ] |
Any performance results with this turbo? How does it perform? |
Author: | gt4hazee [ Tue Sep 16, 2014 12:48 am ] |
Not using this flange if somebody want to buy it from Me. |
Author: | gt4hazee [ Tue Nov 18, 2014 1:52 pm ] |
Sunny How are you running your water ways as I thought they had to be setup , with entering the lower side of the chra to the higher like: http://www.full-race.com/articles/efr-i ... lines.html Also can you tell me the size of the plugs you used on the anti lag ports of the corolla manifold |
