ABS fault http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6857 |
Author: | chippygt4 [ Wed Dec 04, 2013 9:06 pm ] |
Post subject: | ABS fault |
ive looked thru the forum and cant find anything on this, im getting a code 35 abs fault, front left or rear right open circuit. ime getting 1.6 ohms resistance on the front and 0.9 on the rear. both seem to change as they pass the reluctor ring teeth. Has anyone had a similar problem and sorted it? its killing me now.... cheers in advance |
Author: | martinking6 [ Sat Dec 07, 2013 9:31 pm ] |
Post subject: | Re: ABS fault |
I always check all 4 sensors as ive had completely conflicting error codes in the past plus you can compare one side to the other ![]() If the sensors are ok then it may need to have wiring checked, does the light stay on from initial ignition on or does it come on after getting rolling ? Martin |
Author: | two_OH_five [ Sun Dec 08, 2013 12:28 pm ] |
If the light stays on its probably worth running the abs diagnostic cycle Edit, link would help http://wiki.gt4dc.co.uk/index.php?title=Abs_error_codes |
Author: | chippygt4 [ Wed Dec 11, 2013 10:21 pm ] |
the light is on from start up. |
