It is currently Sun Oct 05, 2025 10:02 pm
 Post subject: ABS fault
PostPosted: Wed Dec 04, 2013 9:06 pm
ive looked thru the forum and cant find anything on this, im getting a code 35 abs fault, front left or rear right open circuit. ime getting 1.6 ohms resistance on the front and 0.9 on the rear. both seem to change as they pass the reluctor ring teeth. Has anyone had a similar problem and sorted it? its killing me now....
cheers in advance
 Post subject: Re: ABS fault
PostPosted: Sat Dec 07, 2013 9:31 pm
I always check all 4 sensors as ive had completely conflicting error codes in the past plus you can compare one side to the other ;-)
If the sensors are ok then it may need to have wiring checked, does the light stay on from initial ignition on or does it come on after getting rolling ?
Martin
We now have a new website
PostPosted: Sun Dec 08, 2013 12:28 pm
If the light stays on its probably worth running the abs diagnostic cycle
Edit, link would help
http://wiki.gt4dc.co.uk/index.php?title=Abs_error_codes
PostPosted: Wed Dec 11, 2013 10:21 pm
the light is on from start up.
