driveshaft
http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6769
Author:  tjaytoymota [ Mon Sep 30, 2013 9:04 am ]
Post subject:  driveshaft
Hi am i right in thinking front driveshafts are the same and so interchangeable from side to side cheers ted
Author:  Nibbles [ Mon Sep 30, 2013 11:07 am ]
Post subject:  Re: driveshaft
On a 185 the driveshaft bit from inner CV outwards are semi-interchangable, certainly in emergency. One side has a damper block in the middle, the other doesn't.
The inner couplings into the gearbox are different so you need to split the inner CV (which can be a bit fidly to put back together if it's balls drop out).
Author:  tjaytoymota [ Mon Sep 30, 2013 6:26 pm ]
Ok cheers somebody asked me for ns driveshaft I only got os they looked identical when I removed them diidnt notice a damper on one but prob was lol
Author:  Nibbles [ Mon Sep 30, 2013 6:44 pm ]
It's a big round rubber block about halfway alaong the shaft.
Author:  tjaytoymota [ Mon Sep 30, 2013 8:07 pm ]
Yeah thats why I cant see how I missed it :shock:
Author:  martinking6 [ Thu Oct 10, 2013 7:29 pm ]
No they are different and you can`t interchange them, the main difference is the inner joint where it enters the box
Martin
Author:  tjaytoymota [ Thu Oct 10, 2013 8:38 pm ]
If you unbolt the joints they looked identical same length ect
Author:  martinking6 [ Thu Oct 10, 2013 10:18 pm ]
Aaah my bad I thought it was 205 for some reason, never compared the 2 sides enough to comment sorry
Martin
