It is currently Mon Oct 06, 2025 9:46 pm
 Post subject: driveshaft
PostPosted: Mon Sep 30, 2013 9:04 am
Hi am i right in thinking front driveshafts are the same and so interchangeable from side to side cheers ted
 Post subject: Re: driveshaft
PostPosted: Mon Sep 30, 2013 11:07 am
On a 185 the driveshaft bit from inner CV outwards are semi-interchangable, certainly in emergency. One side has a damper block in the middle, the other doesn't.
The inner couplings into the gearbox are different so you need to split the inner CV (which can be a bit fidly to put back together if it's balls drop out).
PostPosted: Mon Sep 30, 2013 6:26 pm
Ok cheers somebody asked me for ns driveshaft I only got os they looked identical when I removed them diidnt notice a damper on one but prob was lol
PostPosted: Mon Sep 30, 2013 6:44 pm
It's a big round rubber block about halfway alaong the shaft.
PostPosted: Mon Sep 30, 2013 8:07 pm
Yeah thats why I cant see how I missed it :shock:
PostPosted: Thu Oct 10, 2013 7:29 pm
No they are different and you can`t interchange them, the main difference is the inner joint where it enters the box
Martin
We now have a new website
PostPosted: Thu Oct 10, 2013 8:38 pm
If you unbolt the joints they looked identical same length ect
PostPosted: Thu Oct 10, 2013 10:18 pm
Aaah my bad I thought it was 205 for some reason, never compared the 2 sides enough to comment sorry
Martin
