Apexi Power FC http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6530 |
Author: | **BETSY** [ Mon May 13, 2013 11:37 pm ] |
Post subject: | Apexi Power FC |
Ok so I'm still having an issue with my PFC permanently running with the ELD switched on/Lit up? When adjusting idle speed through the power commander I have to adjust idle ELD. The orange wire is connected correctly and working as it should, 12v can be found with the headlights and rear heated screen switched on, this disappears when these two systems are switched off. If I remove the orange ELS wire from the ecu no difference! Any ideas where the ecu may be picking up another signal for ELS? Tia Steve |
Author: | **BETSY** [ Wed May 15, 2013 8:06 pm ] |
Post subject: | Re: Apexi Power FC |
Any pointers? im assuming the Electrical idle up diode is some kind of box/relay assembly? |
Author: | two_OH_five [ Wed May 15, 2013 8:35 pm ] |
What does the battery read via the ecu. It's possible a low reading trumps any other input value Other than that I'm all out of ideas |
Author: | **BETSY** [ Wed May 15, 2013 8:49 pm ] |
The ELD is lit up in sensor/sw check as soon as the ignition is switched on. this never changes even when the car is running and voltage is 12-15v It seems as if the ecu is getting another feed to tell it to run on Idle E/L i have no idea where i may find the Diode Electric idle up with in the car to see if there is another feed from this? I don't think this is to blame though as when i switch the rear heated screen on i get 12v on the ELS wire..Frustrating! |
