Blitz access ecu http://gt4dc.co.uk/forum/viewtopic.php?f=13&t=6482 |
Page 2 of 2 |
Author: | two_OH_five [ Mon May 20, 2013 1:50 am ] |
Post subject: | Re: Blitz access ecu |
Try bridging fp and b+ in the diagnostic connector and see if that makes any difference |
Author: | niblettr [ Mon May 20, 2013 12:45 pm ] |
Also wip the cover off and poke your schnozz in there.If you smell a fish smell, a cap has leaked... They normally weep from the bottom so a bit harder to spot. Electrolite (can't spell) can also eat away at the pcb so may need little more repair work. Sounds like it is the ecu is at fault as you tried a standard ecu and that works... Also, maybe look to see if it drives the charge cooler pump although I wouldn't expect it to run as rough as you are experiencing. |
Author: | zammish [ Wed May 22, 2013 12:04 am ] |
hmmm 185's are getting rare to find now so i cant find another 185 anywher to try it out, as for FP and B+ ive even fitted a walbro fuel pump to stop it from running lean but no good :/ im not really good with electronics but ill give it a go hmmm |
Author: | supersan23 [ Wed May 22, 2013 5:17 am ] |
Where abouts are you too as there maybe a local member near by |
Author: | darrylp [ Wed May 22, 2013 11:21 am ] |
Or you could post it to someone to look / try. I've got a CS so its not likely to work on my car. But Phil ( NoGT4 ) or similar had a 185 .... Also, has this blitz ecu worked fine before ? Its not a new ecu you have just tried to use ? Ad early to late 185s have a few pin differnces.... -- Darryl |
Author: | Nibbles [ Wed May 22, 2013 11:33 pm ] |
I can't really see the focus is so poor, but if you've seen the result then I would guess that's the problem. You're welcome to post off to me to change & repair tracks if you wish, or get someone local who deals with electronics. |
Page 2 of 2 | All times are UTC + 1 hour |
