It is currently Mon Apr 29, 2024 2:24 pm
 Post subject: Combi Meter RPM signal
PostPosted: Sun Mar 03, 2013 11:46 am
Hi folks,
now the next bigger step will be to mount a haltech PS1000 to me 3S, but there is a problem with the rpm signal which comes oem from the ignition, but i will use a PWM
output from the ECU to controll it, i'am pretty sure that many in here are using a stand alone ECU, there are two main questions i have and i'am glad for some help
-how does the oem signal look like?
- how get it converted in the combi meter?
thanks
PostPosted: Sun Mar 03, 2013 12:35 pm
On the standard setup, the tacho is fed from the 'tacho' output from the igniter. I haven't put a sillyscope on to see what it looks like (I can if you wish) but I would hazzard a guess it will be a 5V or 12V pulse train, approx 2mS pulses, 1 pulse per ignition (2 pulses / revolution).
I'm guessing you're fitting a haltech ECU and don't wish to use the standard igniter / coil, but do wish to use the standard RPM meter ?
Are you going coil on plug or twin wasted spark ?
PostPosted: Sun Mar 03, 2013 1:40 pm
A very brief google suggests that you simply switch one of the haltech outputs to Tacho mode
The first result is even about 3S-GTE
http://lmgtfy.com/?q=haltech+rpm+output
Mmmmmm, Haltech Tacos, arrgggggh
PostPosted: Sun Mar 03, 2013 5:26 pm
i will use COPs and yes standart rpm without igniter
the output from the ingiter isn't a PWM signal unfortunetly so, it comes from the minus of the ignition coil over a zener-diod or something like this and gets converted in the combi meter
for the rpm meter,
there are a few guy here in austria which simulate this with a relais coil and a small electronic but this means a further part in the car which i want to safe, so my first plan is to
get a better sight of things and then i will have a look to the combi meter electronic and the sinal and about i can get it working with the PWM signal from the ECU
thats the master plan, plan b is the further electronic
PostPosted: Sun Mar 03, 2013 8:14 pm
I don't understand why you want to use PWM ?
If the ECU has a 'tacho' output available which is a pulse train at 2 pulses / revolution then connect this direct to the tacho. No electronics needed.
PostPosted: Sun Mar 03, 2013 9:58 pm
the issue is the old toyota ignition / rpm signal signal which is not compatible with todays signals,
even the main distributor of haltech here in austria knows that issue and told me of that, i think there is no specific tacho output
looks like a brain storming to me :lol:
PostPosted: Sun Mar 03, 2013 10:11 pm
The forum linked by Steve clearly states there is an 'AUX' output on the ECU to drive tacho pulses. ARe you saying this is not the case ?
PostPosted: Sun Mar 03, 2013 10:37 pm
Use output DPO1 - it has selectable drive levels
http://www.haltech.com/wp-content/uploa ... Sports.pdf
Outputs can be set to drive a tach
http://www.haltech.com/wp-content/uploa ... ons_v2.pdf
The only issue might be that it requires a high level signal like old skool gauges that were wired into ignition coils (unlikely)
If that is the case then you need some trickery with inductors and a transistor/FET to generate the high level pulse
As an aside it's unlikely that the stock uses PWM if it's driven of the igniter circuit. It's more likely to use frequency modulation
However assuming the tacho is an inductive coil analog meter either system will probably work
PostPosted: Sun Mar 03, 2013 10:46 pm
205 i think you has it, the old school system is the problem, but possible i can get it working after a look to the combi meter electronics and what he do with
the igniter signal...if he do anything with it
looks like my friend who did the ic pump controll unit for me has a further job
PostPosted: Sun Mar 03, 2013 11:13 pm
Given the number of celicas running huge fast'n'furious tachos it seems unlikely that the rpm signal is hugely different to the norm
PostPosted: Tue Apr 30, 2013 6:13 pm
here we go
http://www.msextra.com/doc/ms2extra/MS2 ... m#tachoout
looks like i found what i want
Users browsing this forum: No registered users and 115 guests
