It is currently Wed May 08, 2024 4:11 pm
PostPosted: Mon Jan 07, 2013 7:13 pm
I recently purchased a cheap oil cooler setup for the st205. The kit also incorporates a filter relocation kit. The kit is universal and comes with an adaptor that I need to allow the oil takeoff to bolt onto the block. The section that screws onto the block has an m25 thread in it (the adaptor screws into this). As a result I need an adaptor with a M25 male thread to screw into the oil takeoff. Inside this adaptor a female thread needs to be tapped that will screw directly onto the block.
This is a similar oil cooler setup
http://www.ebay.co.uk/itm/SUBARU-IMPREZ ... RTM1089356
you can just about see the two adaptors in the picture, the one I need has the hex head on it
Im really struggling so if anyone has any good hydraulic suppliers it would be appreciated
marcus
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Mon Jan 07, 2013 8:00 pm
I can't find anything like that from the place I usually use - ThinkAuto.
It might be easier to just buy a mocal takeoff plate with -10 fittings on it.
Also that kit doesn't appear to have a thermostat in it?
PostPosted: Mon Jan 07, 2013 8:16 pm
yea, Im using a thermostat up at the filter relocation bit, need to get this part fitted 1st though :D
cheers
