It is currently Thu May 23, 2024 7:30 am
 Post subject: exhaust system advice
PostPosted: Wed Dec 05, 2012 10:00 pm
well iv recently got my self an st205 to replace my mr2 rev 3 turbo which had a 3ince system and i put a berk 3 inch down pipe and im planing to do the same with the gt4 but what this car has a mongoose 2.5 inch system and there seems to be alot of back presure from it when on boost now im just wondering if it would be a bit of a restriction being 2.5 and not 3 inch and would it be worth changing to a 3 inch system ?
PostPosted: Wed Dec 05, 2012 10:30 pm
What other modifications do you have?
Highly unlikely that the 2.5 is causing any restriction unless your running significantly higher power than standard.
PostPosted: Wed Dec 05, 2012 10:56 pm
i have a k@n panel filter and the boost up tp 1.1 thats pritty much it !
PostPosted: Wed Dec 05, 2012 11:15 pm
From experience if you replace the cat and front exhaust section (including the flexi) with a 3inch downpipe and front pipe then mate it to a 2.5inch centre and back section this would handle up to 330bhp @ 1.2-1.5bar. The larger diameter at the turbo exit has a greater beneficial effect on engine response than a large diameter centre and back section.
PostPosted: Thu Dec 06, 2012 8:55 pm
cheers lads il just stick with what i have so and get the berk down pipe.cheers for the inputs dudes !
Users browsing this forum: No registered users and 1 guest
