It is currently Mon Oct 06, 2025 6:20 pm
 Post subject: Gear change
PostPosted: Thu Sep 06, 2012 11:23 am
Hello,
I have a problem with changing gears. Most problems I have with the third gear. When engine is off I can change without problems from 1st - 5th with pressing clutch.
When engine is running, gears a hard to get in and most problems with 3rd gear. But this problem is only sometimes!
Complete clutch is not very old, max. 15.000km (ogura 409 i think)
Any ideas?
PostPosted: Thu Sep 06, 2012 11:51 am
I would guess you have a little clutch drag.
Many aftermarket clutches require a little more travel than standard to fully disengage. This requires the pedal stop to be moved up and the master sylinder clevis adjusted a bit longer so you end up with more pedal travel.
A quick search on here for 'clutchmasters' should yeild more information on how to adjust.
PostPosted: Thu Sep 06, 2012 11:54 am
p.s. If it was ok and now getting worse, it is worth checking the bolts holding the clutch onto the flywheel are still done up. You can access bolts on a standard flywheel by removing the starter motor. (I know a twin plate setup that had this problem, you could access via the hole for the release arm)
PostPosted: Thu Sep 06, 2012 12:42 pm
Thanks for your answer! I don't understand why i Need more pedal travel now?
